Results 1 to 18 of 18
    Aug 2001
    Indiana
    ive been working on this for a long time and i need help.. ok i have a mpg.. its in mpg layer 2 does it have to be in layer 1 for me to use my adaptec 4.0 deluxe to burn it to vcd?? cause ive been having trouble burning it.. it generates it really quick and burns it quick so i know its not burning the movie...i get some error thing.. but i say add anyway.. it does that... what do i do.. does it need to be in... mpeg layer 1?? please help thank u in advance ..
  2. EZ CD Creator 4 Deluxe only burns standard VCDs so your video will have to be VCD compliant MPEG-1 files. If you click on "What is VCD" on the menu to the left, you'll see the specs that it has to be.
    SVCDs use MPEG-2, but Easy CD creator 4 cannot create SVCDs.
    BTW, MPEG-1/2 Layer 1/2 refers to the audio. Both VCDs and SVCDs use audio encoded in MPEG-1 Layer 2 audio.
    Regards.
    Michael Tam
    w: Morsels of Evidence
    Aug 2001
    Indiana
    well from the mpegprop i downloaded it.. it says its an mpg layer 2 ( thats under the audio tab) how can i get that to layer 1 so i can put it on a vcd?
    thanks
  4. Read my previous post carefully. The audio is supposed to be in MPEG-1 Layer 2.
    There is something else wrong with your MPEG file. What does Easy CD Creator say is wrong?
    Regards.
    Michael Tam
    Aug 2001
    Indiana
    its got a red X by Frame rate :
    Unavailable
    and
    system clock:
    1084
  6. Okay.
    Play the MPEG in Windows Media Player. Look at it's properties (File --> Properties). You should be able to read the spes of the mpeg.
    For a MPEG to have even a chance of being VCD compliant it must first have the following:
    encoding (video): MPEG-1
    framesize: 352x240 (NTSC) or 352x288 (PAL)
    framerate: 29.97fps (NTSC) or 25fps (PAL -- or 23.976fps (NTSC FILM)
    video bitrate: 1150 kbit/s
    encoding (audio): MPEG-1 Layer 2
    bitrate: 224 kbit/s
    audio: 44.1 kHz, 16bit stereo
    If any of the above are wrong, then your MPEG can't be VCD compliant without re-encoding.
    If all the above are correct, you could try demultiplexing and remultiplexing your MPEG. You can do this with TMPGEnc (File --> MPEG Tools). If you do it this way, make sure you select MPEG-1 Video-CD for the muxing rather than MPEG-1 Auto.
    Regards.
    Michael Tam
    Aug 2001
    Indiana
    ok my video is
    352x288
    frame rate was 59.94
    1150 kbit/s
    audio
    mpeg 1 layer 2
    192 kbit
    48 khz..
    and i know i can encode it agiain in either 29.97 or 25 fps... and see if that works... but what about the others things.. that dont match up?? thank u for all ur help
    Cory
    Aug 2001
    Indiana
    ok i converted another movie and it has...
    all that stuff im pretty sure but i still get an error... it says system clock reference. with the little red X next to it ... and it still wont burn.. and it had a number next to it, it was like 1058 or something like that.. what do i do, do u know??
    thanks for all ur help
    Cory
    Aug 2001
    Indiana
    please help
  10. Banned
    Jun 2001
    UK
    What are you using to convert it to VCD ?. TMPGENc has templates that you can load, this then produces a VCD mpeg that is exactly correct.
    The red X indicates the "exact" fault, it tells you what it is !! 1058 sounds like kbit/s this is not correct.
    Video-CD PAL (MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
    As you can see from this PAL VCD, its 1150kbps.
    Aug 2001
    Indiana
    i know but im still having problems... i keep getting the system clock reference error... and it wont burn i dont know... any help is much appriciated..
  12. Banned
    Jun 2001
    UK
    What are you using to convert the movie ?
    Aug 2001
    Indiana
    tmpgenc.. sorry
  14. Burn with Nero, it surpasses EZ Cd creator so much, it's disgusting. You are using the videoCD template when you re-encode, right?
    Aug 2001
    Indiana
    where can i get a copy of nero im pretty sure i have it on my computer but it wont work cause i already used my free trial thing
  16. Banned
    Jun 2001
    UK
    Hi Again
    Ok, you are not loading the template when you are using TMPGEnc, so it is not producing a fully compliant VCD mpeg.
    Use the template you will not have any problems with Easy cd creator, unlike a million users on here who constantly complain about Nero !! don't take my word search the messages.
    he he
    Aug 2001
    Indiana
    thank u sososo much for ur help just one more question how do i load the templete i cant find it and when i find it i should use the PAL one right?
  18. Member
    Aug 2001
    Indiana
    ok i got it thank u soosososos much all of u that helped me
