Hi,
Could someone please tell me how to install cce 2.5 so dvd2dvdr will find it. I currently have it installed in c:\program files\custom technology\ cinemacraft encoding. I tried every place I can think of with no luck.Please help.
Regards
Glaker
Thanks for the reply but dvd2dvdr does not find cce 2.5 can any body else help please
it probably means you have another version, DVD2DVD-R supports only CCE 2.5
[-Neoh*-]|[-Cheers-] -
glaker
I got the same problem:
8:13:48 PM checking Filesystem...OK
8:13:48 PM checking free Diskspace for ripping...OK
8:13:48 PM checking free Diskspace for encoding...OK
8:13:48 PM checking Outputfolder...OK
8:13:48 PM checking Outputfile...OK
8:13:48 PM updating PTS-Values... OK
*** IfoEdit-Mode ***
8:13:48 PM starting RIP
8:14:42 PM finished RIP
8:14:42 PM starting Audiocheck
8:14:45 PM finished Audiocheck
8:14:45 PM searching for DVD2AVI and Plugin... OK
8:14:45 PM updating Registry for DVD2AVI... OK
8:14:46 PM starting DVD2AVI... OK
8:14:47 PM searching for AVISYNTH.DLL... OK
8:14:47 PM updating Registry for AVISYNTH... OK
8:14:47 PM searching for MPEG2DEC.DLL... OK
8:14:47 PM creating Avisynth-Script... OK
8:14:47 PM creating IfoEdit-Chapterlist... OK
8:14:47 PM writing Protocol... OK
8:14:47 PM creating Cinemacraft Encoder-Script... OK
8:14:47 PM searching for Cinemacraft Encoder... FAILURE
8:14:49 PM ERROR
and a red pop-up window "File not found"
:cry:
I post this issue before:
http://www.vcdhelp.com/forum/viewtopic.php?t=130647&highlight=dvd2dvdr+cce
I want to confirm:
1, The cce version is: 2.50.01.00
2,The cce path is:C:\Program Files\Custom Technology\Cinema Craft Encoder SP\cctsp.exe
and OS is in c: also.
3,Only 1 version cce in my PC, never install other version cce.
4,I do try dvd2dvdr 1.3.2, 1.3.3,1.3.4, no one work!!!
5,My OS is win2k with sp3
6,I do try to uninstall all of them and install cce and dvd2dvdr in difference order, it still dosen't work
Right now,I really wonder:
How does dvd2dvdr locate cce??????
Anyone there got the same issue? I am sure this is a software bug.
will not install
By ka3wjz in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 30th Jun 2009, 21:07 -
Can't install XP SP3
By JudgeGarth in forum ComputerReplies: 9Last Post: 5th Dec 2008, 00:07 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43 -
Use without an install
By raschko in forum Newbie / General discussionsReplies: 0Last Post: 9th Aug 2007, 16:37 -
install
By Brasilman in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 29th May 2007, 09:17
