Is there a list somewhere of which files were installed when the drivers were installed? I want to uninstall the drivers ( all the way ) so I can make sure when i install this new TV card the drivers install will be clean.
If someone can point me somewhere
Thank you
"Computers are stupid, but they are capable of being stupid one million times per second"
Hi,
I'm assuming you're using Windows XP? Click on the start button, then click on Control Panel. In there, click on Perfomance + Maintenance, then click on the System folder. Go to Hardware, and click on the Device Manager option. In the list that follows double click on 'Sound, Video, and Game controllers' You should see the driver listed in there for your video capture card, if you click on it, it will give you information about that driver. Hope this helps
John 14:6
Nvidia drivers question for new installation
By A Traveller in forum LinuxReplies: 20Last Post: 12th Oct 2011, 12:45 -
Question about deleting USB drivers to fix lack of USB notification
By jimdagys in forum ComputerReplies: 13Last Post: 15th May 2010, 11:24 -
Help! Where Do I Get New Drivers?
By RayPaula in forum DVD & Blu-ray WritersReplies: 3Last Post: 13th Jan 2010, 10:13 -
question about installing drivers
By jimdagys in forum ComputerReplies: 6Last Post: 10th Apr 2008, 00:50 -
Blue screen when installing Hauppage WinTV 150 drivers from website
By ponyboy in forum Capturing and VCRReplies: 1Last Post: 5th Mar 2008, 23:55
