recently whenever i burn a (avi-divx)disc no conversion is being done
i get bad frames. Before burning i scan for bad frames or wath the film to verify there are no bad frames but after the burn when i try to watch the video or scan for bad frames(Vdub) i get bad frames or an avi read error.
my theory is that the bad frames and read errors are caused by CRC errors resulting from the burn. this is what i have tried:
Derfrag, using various programs: NERO, Easy CD, PRASi, & the burner ap that came with Win XP. Also I did a fresh reinstall of Win XP Home when I tried each of the burning Aps to make sure there were no conflicts. Also i tried cleaning the lens and using different media and burning @ 4x the slowest the burner allows and this has had no effect.
i've had the burner (Acer CDRW 20X10X40) for over a year and i don't think i was having this problem when i first got it so i'm going to try a new burner any suggestions as far as which burner is the best i don't need speed just reliability---->NO BAD FRAMES AFTER BURNING :P
Results 1 to 1 of 1
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 18:39 -
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 09:15 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 16:00 -
.avi file cannot be repaired - need to remove bad/corrupt frames
By realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 13:27 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 04:39
