    Oct 2002
    Can I make chapters with TMPGEnc plus 2.5?
    If I can...How do I do it?
    If I cant ...Is possible to do it with help of an other program.
    If it is..with what program?
    8)
  2. No, TMPGenc just makes the MPEG file. Chapters are made by the burning software/VCDImager XML file.
    Take a look to the left under "author" you can find faqs to make/burn x(S)VCDs with chapters (aka entry points). If all you want is simple 'chapters' then try VCDEasy, for more advance features try TSCV.
    Oct 2002
    Ah thanx I'll try that
    grrrrrrrrrrvooffff
    Oct 2002
    btw were can I find the best guide to make chapters?
    grrrrrrrrrrvooffff
    Oct 2002
  6. Try using the "Search" function for more hits. I found this: http://www.vcdhelp.com/forum/viewtopic.php?t=84327&highlight=
    To understand how chapters themselves work: http://www.michaeltam.com
    VCDEasy is recommended: http://www.vcdeasy.org
    Regards.
    Michael Tam
    w: Morsels of Evidence
