i have been using tmpenc.exe to convert avi to mpeg that is done successfull when i exit the program says
" the instruction at "0x021f1039" referenced memory at "0x02350cd0". The memory could not be "read" click ok to terminate the program
Any how after that i go to nero i drag the file over it adds then when i click burn it says the file invalid need mpeg-1 which was encoded for video cd. it then says the following problems were found, stream encoding which is invalid for vcd and invalid audio stream 44000 hz , 2 channels.
Then says i am creating video cd v2.0 (cd-i player) compliant cd, but the mpeg file is not suitable for such a disc how would u like to proceed 1:turn off standard compliance and continue 2: reencode the video file 3: cancel
i once chose 1 and burned on a cdrw and it played when i burned on a cdr it did not play why? please help tell me what to do!!! please thanks
i am not having the problem with tmpg, everything appears to work fine, but i can't burn onto a cdr, only a cdrw (having it know that there is a vcd in). i've tried to different brands of cdrs too. help please!
i use tdk they are good for making psx copies and auudio cd's they should work to make vcd too right?
please someone help !!! -
Hi
When you use TMPGEnc, "Load" a template, chose a PAL or NTSC VCD template. The output will then be exactly correct for the burning programs. -
hi umm i chose pal vcd should this make it burn unto cdr now? anyhow im trying . love its a waste of alot of money.anyhow thanks ive gotta get it .
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 17:55 -
CDRW Erasing Cancelled - CDRW NOT WORKing
By Sarao in forum ComputerReplies: 6Last Post: 5th Feb 2010, 10:55 -
How to burn AVI files onto CDR?
By doofdoofdude in forum Newbie / General discussionsReplies: 2Last Post: 18th Apr 2008, 10:08 -
burn vob into cdr
By pcb in forum Newbie / General discussionsReplies: 10Last Post: 18th Feb 2008, 12:28 -
How Can I burn a 90 min data CDR Image to HD Folder
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2008, 19:48
