but it took about 2 and a half hours to do. Is there anything I can do to make this go faster?
Results 1 to 10 of 10
Could you PLEASE tell us more. What tools you used and settings.
And wait at least some days before you bump your topic. -
Sorry I am used to going to a huge message board on GameFAQs.com where you bump topics after about 30 minutes. Anyway.
I want mostly avi files made into DVD format with sound without having to use TMPGEnc or if I do use that I don't want it to take 2 and a half hours for a 20 minute video. I have a 1.2 GHz AMD Athlon processor and 384 megs of RAM and a GeForce 2. -
The only reason I use TMPGEnc is because when my other program which converts it faster does it it has no sound. Can I fix this somehow?
hey im stuck with m2v files and there audio now what do i do wid em to get them on dvd? what programmes do i use? help me i just want this on dvd its a film of the new years eve ive uploaded on cam off the pc and it was an AVI, and ive added a title and a menu, ALL SEPERTATE FILES! help me please
DVD'S HAVE SOMETHING FOR US ALL, HELP AT THE FORUMS TO GET SOMEWHERE IN LIFE! -
I'm looking at your specs and have come down to two conclusions-
1)You probably used high settings for it to take that long. Nothing wrong with that, but perhaps next time you should do it, and then go to sleep so you can wake up and its done
2)Your pc itself. You are usinga 1.2 Ghz T-bird. The T-bird never had compatability with SIMD instructions and perhaps this is what slowed you down - it might bemore noticable as you'd see "hiccups" in games (The AthlonXP has these instructions [save for SSE-2] and a much powerful FPU to boot) or other applications. You are also not using the fastest RAM known to man. PC133 is fine, but if you had a faster kind (I can't tell if your motherboard will support DDR because you didn't list the make) of ram that might make a difference.
Also your HDs make a difference. The harddrive is the most overlooked aspect when it comes to speed (most care for size), and it makes a lot of difference if you can get a faster one because it is ALWAYS the bottleneck in any situation. Is it a ATA33/66/100/133? That isn't the most important part though - look at the seek time. True 7200 RPM is faster, but if a 5400 RPM has a lower seek time AND it can read more data per "rotation" then that would be viable option.
And last but not least, We have no idea what your motherboard is. The KT266a was such an improvement over the KT266 (I'm guessing you are running a KT133a....) that people were literally getting much better results- IE- 20-30 FPS higher in games... Same with the NForce2 and the KT-400 (If there are any Intelers that want to add some of their own lingo add it :P ). When running games in lower resoutlions (800*600) the nforce2 was about 20 FPS faster...Also is applications it finished "stuff" faster
Because if you have abad motherboard, the fastest processor in the world can't do anything. That is why "I dislike it when I know people who go buy that beefed up CPU but skimp on the MOBO as if it isn't important
I'm not sure how that would convert to encoding, should make some kind of difference jumping kt266 to kt266a ( though that is more of an extreme example)
Because oddly when I try to make a SVCD I stick it at a bitrate of 2000 and it takes me about 20 minutes to encode and all (when it actually reaches 100%). -
Here is all my info.
Microsoft Windows XP Professional (5.1, Build 2600)
AMD Athlon Processor, MMX, 3DNow, ~1080 MHz
384MB PC-133 RAM
Direct X 8.1 (4.08.01.0810)
NVIDIA RIVA TNT2 Model 64/Model 64, 32.0 MB
Current Display Mode: 800 x 600 (32 bit) (60Hz)
ViewSonic A90 19" Monitor
VIA Audio (WAVE), Type WDM -
Oh and my motherboard is a
AOpen
AK73 PRO (A)
AMD Athlon Thunderbird & Duron Socket A 4X AGP ATX Motherboard
Creating a 2 minute video
By mgk103 in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2011, 10:26 -
mp3 plays on Windows Media Player but won't play last minute in Sound Forge
By wetcamelfood in forum AudioReplies: 2Last Post: 1st Dec 2010, 16:47 -
How much bandwidth is used in a typical 1 minute video?
By chrisj in forum Newbie / General discussionsReplies: 10Last Post: 13th Mar 2009, 15:37 -
Get snapshots from video files every XX minute
By roglopes in forum Newbie / General discussionsReplies: 2Last Post: 8th Jun 2008, 22:07 -
Want to take 0.25 sec video clips from a 10 minute video
By videocheez in forum EditingReplies: 2Last Post: 2nd Jun 2007, 20:36
