Newb question, sorry. Trying to test out burning an mpeg to a vcd for viewing on my dvd player (yes, mine supports vcd's). I'm using Nero on Win98, and grabbing mpeg files off Kazaa for testing. It seems to burn fine, but the .dat file won't play on Media Player, and in my dvd player will either play partial or not at all. Could this be a problem with my source .mpeg files (I've tried 3-4 different ones) or am I doing something wrong?
well make sure in media player u hit at the bottom show all files to open the .dat and if that doesnt work, then maybe update windows media player, i have heard before that changing the registry settings will let .dat play in media player if it isnt at the moment. but i forgot where i saw that sorry. and as for the dvd player not playing it, some dvd players cant play cd-r's(which im guessing ur using) check the dvd player section on this site, maybe that can help.
Cartman "Im gonna kick you in the nutts!" -
I'm able to see and load the .dat file in mplayer, the file name will be there and all - it just won't play. It'll either say 'no combination of filters could be rendered to filter the stream' or else no message at all.
I've tried both cd-r and cd-rw on my dvd player, the cdrw's didn't play at all, the cdr's would play partially and without sound.
HD Audio Query
By anirban in forum Newbie / General discussionsReplies: 1Last Post: 4th May 2011, 11:08 -
CD media query...
By mjl1297 in forum MediaReplies: 4Last Post: 17th Nov 2010, 23:35 -
DVDStyler query...
By mjl1297 in forum Authoring (DVD)Replies: 0Last Post: 20th Jul 2010, 05:36 -
Lossless Query
By anirban in forum AudioReplies: 11Last Post: 12th Oct 2008, 12:55 -
LG2T160 Query
By coolboarderguy in forum DVD & Blu-ray RecordersReplies: 0Last Post: 7th Jul 2008, 08:07
