i am haveing trouble on fitting movie on cd i have used the newbie guide but cant get it to work can anyone help?
Results 1 to 9 of 9
be sure to use tmpgenc 2.58, 2.59 has a bug when you make xvcd.
http://www.vcdhelp.com/forum/viewtopic.php?p=403176#403176 -
cant get tmpgnc ver 2.58 it takes me to 2.59 and i cant get it to work help me please
I've got AOL IM and MSN messanger. Do you run either? I'd like a copy too please....Originally Posted by davemcg37
THANKS.... -
Baldrick, normally, VCDhelp doenst condone members to contact each other about getting older versions of software, but in this case, where the newer version just doenst work right, is it ok?Originally Posted by Baldrick
wouldnt you have to make the quality bad so the mpeg file size is smaller to fit on 1 cd?
it is indeed an xvcd and the bitrate you get is totally dependant on the length of the movie. some movies are slightly lower than standard vcd quality (1150kb/s) some are greater, and then you can split the movie in half in Tmpgenc and do a "two disc encode" using the 1 disc template, so getting near svcd quality. also if you're not too bothered about the audio being super high quality you can drop the audio bitrate and get more on the video bitrate.
Fitting more onto a DVD
By Woolen Llama in forum Authoring (DVD)Replies: 14Last Post: 23rd Sep 2010, 07:31 -
Fitting more in the dvd
By btkuehn in forum Newbie / General discussionsReplies: 2Last Post: 17th Nov 2008, 17:53 -
fitting more than one movie on a dvd
By LaLuna in forum Newbie / General discussionsReplies: 4Last Post: 21st Jan 2008, 19:15 -
Help Fitting Videos on CD...
By skinnerback in forum Video ConversionReplies: 4Last Post: 4th Sep 2007, 17:12 -
Fitting more onto single DVDs
By ells6363 in forum Authoring (DVD)Replies: 32Last Post: 18th Jun 2007, 03:57
