Can someone please help me. I've been using CladDVD XP ver 1.3 as a ripper. I like because it is very easy and you can create a frameserving file to tmpgenc to reencode the vob files. I went to open clad today and get and error message that states "This program can NOT run as it has EXPRIED!!! download the latest version."
I did this and ran it, even though the version # and the date it was posted are the same as the current ver I'm running. No change I then, per the website installed MS visual basic 6.0, still no change. I then ran aspichk.exe to check my aspi layers it reads
"ASPI Layers"
apix.vxd ver 4.6
wnasppi32.dll ver 4.6
aspi layer properly installed & fully operational
ver 4.6, according to the website, is the aspi ver I need for running cladDVD under win 98se. Does anyone have a clue to what, if anything, I've done wrong?
If I cannot fix Clad, is there another ripper program that is just as easy to use and will also create a .d2v file to frameserve the .vob files to Tmpgenc?
Thanks for the help.
Another thing I did try is to download the so called "Latest version" onto another computer that I have that has never had this program on it. I got the same error message. Maybe for some reason this is no longer a valid program?
Premiere Pro 'Error Compiling Movie - Unknown error'
By koberulz in forum Newbie / General discussionsReplies: 12Last Post: 16th Sep 2012, 16:43 -
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
Error: The source image format is not acceptable (error code -2)
By Russo in forum DVD RippingReplies: 3Last Post: 5th Jul 2011, 10:50 -
source filter error (Error=80040241) when playing HR Avi
By mwm in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 10:03 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
