Hi!
This might be a stupid question but..
I have a SVCD that I`m trying to copy on to my hard drive. I have tried to copy and paste, wich only makes the MPEG2 folder on the cd "not responding".
I have tried to burn an image with Easy CD Creator from the cd to my HD with the same result as above.
I have tried to copy the MPEG2 file from the CD with VCDgear2.0 with the same result as above.
I`m sure there is a simple way to this but I cant seem to find it.
Any help would be highly appreciated.
Best regards
kimert
Try opening up the MPEG2 folder and copying and pasting the AVSEQ01.MPG (or whichever one is the largest, if there is more than one of them) file to your hard drive.
Thanks for ur reply papaholmz!
I tried IsoBuster and it worked fine. Problem solved
Regards
kimert
copying streaming
By ruthann in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jun 2011, 12:14 -
copying
By merc68 in forum DVD RippingReplies: 13Last Post: 7th Nov 2009, 18:26 -
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 22:03 -
copying????
By bamf321123 in forum DVD RippingReplies: 1Last Post: 23rd Jun 2007, 07:39 -
Copying DVD
By carper in forum Newbie / General discussionsReplies: 4Last Post: 6th May 2007, 10:41
