Hi Sup! I Need help here....i've been trying to decode the sound from a .mov file....I dont know how! i tried many program, virtualdub, Dbpoweramp...etc *Please show me.
How, With .....! THANK YOU VERY MUCH!
1. Install Quicktime.
2. Download the Quicktime VFAPI plug-in for TMPGEnc.
3. Install TMPGEnc.
4. Raise the priority of the Quicktime VFAPI plug-in in TMPGEnc environment settings.
5. Open the Quicktime clip in TMPGEnc.
6. Select File > Output to File > WAVE file.
7. Save As CD Quality PCM WAV file.
8. You're good to go. -
Sorry but...where can i find the quicktime plug-in?
And thanx for the help! -
You can get it here http://www.geocities.com/SiliconValley/4942/svcd.html. Click on QTReader.vfp and follow instruction.
Sup! hummmm, there's another problem i can decode the wave file but the wave file as no sound....whats wrong, i did all the things u said.
Decode LG HB405SU
By ShaunA in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Jan 2011, 09:43 -
DivX and XviD decode only
By CSULB71 in forum Software PlayingReplies: 10Last Post: 20th Apr 2010, 10:33 -
Question about decode
By Russo in forum Newbie / General discussionsReplies: 7Last Post: 16th Apr 2009, 13:30 -
What is being used to Decode?
By tb582 in forum Video ConversionReplies: 12Last Post: 9th Sep 2008, 16:15 -
Decode with Quicktime
By Nekesu04 in forum ffmpegX general discussionReplies: 2Last Post: 13th Jul 2007, 17:25
