  1. in TMPGEnc there are a few setting that have to do with motion searching, can anyone explain to me the importance of it and how it effects the output file? Thanks
    Mar 2002
    United States of America
    Motion search precision adjusts how much the encoder searches for motion between different frames. This means it looks at a block in a frame and then looks at the next frame for the same (or similar, depending on other settings) block somewhere else in the picture. If a similarity is found, information on the direction and how much the mpeg block moved between the 2 frames is put into the mpeg stream, so that the block is used
    in a different place in frame 2. By doing this the same thing isn't encoded twice. This means that less bits are used when things are repeated. then bits can go to other things like encoding the block better in the 1st frame.
    Setting the motion search precision to the highest quality (slowest) setting will make the encoder search really hard for repetition between frames. This makes the picture a lot better when things are moving.
    If you encode a video with only small amounts of movement, you can sometimes get away with lower settings to save time, but even in low motion pictures, different parts of the image might be the
    same, so I always use the highest setting to give the best picture.
    Hope That Helps!!! :P
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Nicely explained P138, thanks!
    Mar 2002
    Your welcome!!! :P
