If i produce 2 versions of the same fotage one in NTSC other in PAL and burn its with nero, my dvd switch the region each time ????
I'm not sure exactly what the question is.
However, many DVD players are compatible with PAL and NTSC - just encoding in a format does not set the DVD region - normally your DVDr's will be region free (play on any DVD player) unless you set the regions in the VIDEO_TS.IFO when authoring.
I hope that clarifies things for you -
Question is... from where did you get your "footage" ?
And what makes it region 1,2 or free is authoring and not burning.
So if you are meking your own home video, it should be region free.
If you are ripping (backup) DVD, it depends on how you do it. -
PLEASE TRY TO ASK CLEAR QUESTIONS, IF YOU WANT CLEAR ANSWERS!!!
Now that I got that out of the way, If your DVD player is compatible with both NTSC\PAL, yes you can place both clips on the same disc and the player will automatically adapt to the proper television standard.
-Epi
Pal 25i to Ntsc question
By spiritgumm in forum Video ConversionReplies: 17Last Post: 15th Dec 2011, 18:16 -
PAL to NTSC question
By rayden54 in forum Newbie / General discussionsReplies: 11Last Post: 2nd Apr 2011, 21:59 -
PAL vs NTSC Question
By cottage in forum Video ConversionReplies: 26Last Post: 6th Jul 2009, 09:53 -
FAVC Pal-Ntsc conversion question
By spiritgumm in forum Video ConversionReplies: 4Last Post: 24th Feb 2009, 10:12 -
pal/ntsc lcd monitor question
By scotstrength in forum Media Center PC / MediaCentersReplies: 0Last Post: 30th Oct 2007, 12:17
