OK, this is following up from my last topic . . . I wasn't getting any audio with my burned (S)VCDs on my Philips 724.
I've fooled around with the player a little bit more and have found that if I don't use the composite audio connection and just use the standard audio out my (S)VCDs work fine, including the audio.
Using the composite audio connection I do not get sound with my (S)VCDs. However using an ISO CD-ROM with MP3 files (128kbps) works just fine.
Is there a minimum audio setting that has to be used for audio to work using composite connection? My MPEG file that I am testing with has the following properties (taken from TMPGEnc):
MPEG-2 352x240 29.97fps CBR 2000kbps, Layer-2 44100Hz 192kbps
Again, any help would be appreciated.
Results 1 to 1 of 1
Canopus AceDVio composite capture problem (Svid works, but not composite)
By bfrandse in forum Capturing and VCRReplies: 3Last Post: 28th Oct 2008, 10:55 -
Create an uncut composite by editing the audio track
By TRAXX-74 in forum Authoring (DVD)Replies: 3Last Post: 12th Sep 2008, 19:32 -
Hauppauge HVR-1800 Composite input - NO AUDIO
By jhg in forum Capturing and VCRReplies: 8Last Post: 1st Jul 2008, 16:20 -
Composite IN vs S-Video IN (using converter wire composite to s-video)
By goal in forum Capturing and VCRReplies: 2Last Post: 29th Mar 2008, 21:19 -
Philips DVP5960 HDCP Question /// HDMI -> DVI and Composite Audio?
By cactusPhone in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th May 2007, 22:32
