hi,
I'm really new to this thing and need some advice. I burned my first VCD in nero 5.5 perfectly. Then it seemed not to work on subsequent attempts. So I installed a trial version of 'RecordMax' (by stomp). This allowed me to make VCD's again with no problem, but i wanted to burn SVCD's so installed the mpeg 2 codec from nero. Still no luck, and even worse it won't burn my audio CD's either now![]()
. Nero says it has burnt succseffuly but when you try to play back even audo on my music centre it will only play the first second and them stop, although it recognises that there are say 4 tracks on it.
Now I read that if you have Nero burning installed that you should not install another burning programe as the drivers usually interfer with each otherI have tried uninstalling Nero and recordMax...all to no evail
Please please can someone give me some advice before I go mad![]()
I've lost so many CDR's now(
Thanks in advance for any help any on can give me
Chris
I dont know how new you are at this, so im going to suggest that you do this............
Make sure the you finalize the CD. -
Download VCDEasy as VCDEasy can burn SVCD's and VCD's. It also fixes many problems with burning that Nero has.
Hope That Helps!!! :P
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Nero only burning at 1x...?
By VEBouto in forum Newbie / General discussionsReplies: 2Last Post: 20th Jun 2008, 23:04 -
Burning vcd/svcd full length film.........
By marcgarcia in forum Authoring (VCD/SVCD)Replies: 2Last Post: 15th Oct 2007, 21:07 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56
