My current SVCDs are pretty good but should I use a denoiser for a DV/D8 camcorder source when encoding SVCD? Some parts of the original footage are quite noisy.
MediaPipe offers the following options:
- "Temporal Denoiser" (with n, n-1 and n-2 Temporal Weights and a Threshold value) and
- "Noise Filter" (with 2x2, 4x4 and 8x8 analysis depth and Light-Strong Filter strength)
...but I really don't know which one (or both?) and which options I should try with my D8 videos. Are the default options OK?
Should I use the denoiser before the Scaler?
mpeg2enc -N didn't make much visual difference when I tried it but should use it, too?
BTW, at the moment I'm trying to decide whether to encode the original 720x576 PAL to 352x288, 352x576 or 720x576 XSVCD with 48kHz audio so that I can easily use the MPEG2s on DVDs (those are also DVD resolutions) later or should I just stick to 480x576 44.1kHz SVCD (which must be re-encoded for DVD either from the original DV/D8 or ripped, rescaled and re-encoded from the SVCDs if there is no original footage).
My standalone Pioneer 444 DVD player plays all those resolutions and audio options just fine.
Progressive (X)SVCD output is less blocky than interlaced but I prefer interlacing for its motion smoothness on TV.
352x288 XSVCD must be progressive. On the other hand such a low resolution doesn't get blocky with 2500 kb/s as the higher resolutions tend to do. Of the interlaced options:
352x576 is quite nice but the low horizontal resolution does show in some vertical straight lines as fuzziness. For example, a distant red house with horizontal panels displays better with more horizontal resolution than 352.
720x576 is surprisingly good although some moving scenes tend to get blocky easier than with lower resolutions. Maybe a good amount of denoising would make 720x576 the winner of these XSVCD resolutions?
p.s. SVCD on a Macintosh memo and cookbook is at:
<http://www.sjoki.uta.fi/~shmhav/SVCD_on_a_Macintosh.txt>
Try YUVdenoiser:
http://www.info.polymtl.ca/~anmis/YuvDenoiser.tgz
Download it and put the pipe on your /library/MPipes Folder.
(note: u need to use Color Conversion befor and after the YUVdenoiser)
Camcorder Color Denoise
By rurimoon in forum Video ConversionReplies: 5Last Post: 6th Jun 2018, 05:59 -
xvid4psp crashes if denoise is enabled
By codemaster in forum Video ConversionReplies: 1Last Post: 30th Apr 2012, 16:40 -
denoise before editing, or after ?
By codemaster in forum RestorationReplies: 1Last Post: 26th Apr 2012, 12:27 -
Denoise filter ? which one is the best ?
By cd090580 in forum Newbie / General discussionsReplies: 35Last Post: 19th May 2011, 09:34 -
Help with Denoise Filter
By skorpinok in forum Video ConversionReplies: 0Last Post: 1st Jan 2011, 02:59
