Alright i have this XVID movie which is 576x240 resolution now i follow the guide: http://www.vcdhelp.com/tmpgencsvcd.htm and i did this right down to the last detail,with all my specs matching it.I also used this guide: http://www.vcdhelp.com/forum/userguides/119019.php
and changed my settings as it said i have made two files using virtual dub one with audio and no video the other with video and no audio as the guide says, I burnt it as a NTSC FILM, it previews fine as its doing it and even when i burn it there are no problems. It also is fine when i play it in WMP, but then when i play it on my LG DVD player and the picture is totally screwed its flickering with two big black lines on the screen cutting the picture into 2 and bit parts showing the movie that many times, the video is the colour is black and white. The audio is fine and in sync but the picture is screwed u can see the movie but as i said it is totally screwed. Please if anyone has any advice i would be most grateful ive already wasted 3 cds please any help would be much grateful.
My settings are:
non-interlaced
bottom field first (field B)
1:1 (VGA) aspect ratio
im using toolame as external audio program
Constant bitrate(CB)
Fast motion search
1600kb/s
VFAPI exactly the same as the above site i mentioned
full screen keep aspect and ratio
4:3 display
movie resolution: 576x240
movie frames: 23.976fps
audio sampling rate: 48000hz
audio channels: 2(stereo)
audio compression: MPEG layer-3 codec (professional)
Results 1 to 1 of 1
my xvid videos are too big in filesize
By C-Royd in forum Video ConversionReplies: 1Last Post: 6th Aug 2011, 16:31 -
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
Nero converting vob to avi,,,files way to big after????
By jcurrieirocz in forum Video ConversionReplies: 7Last Post: 17th Nov 2008, 19:41 -
Big blocks on XVid to MPEG conversion
By hewsongs in forum Video ConversionReplies: 7Last Post: 30th Mar 2008, 15:50 -
cannot seek in big (>2 GB) XVID files
By adwiel in forum Video ConversionReplies: 1Last Post: 25th Jan 2008, 00:41
