Mine defaults to the Ligos decoder which I guess comes from MediaStudio Pro and I am not happy with it as it shows interlace lines. I would like WMP to use the Cyberlink PowerDVD decoder instead - is there any way in WMP or XP Pro to choose a default decoder ?
Ligos codec has a high priority so I would use PowerDVD to watch your
videos. -
Thanks. Is there anyway to change the priority?
I use WMP for 90% of the time, mostly for quick test viewing of encoding and/or rendering results. I find it much more convenient than PowerDVD as it loads up much faster and generally uses less mouse clicks to operate, and I do not have to maximise/minimise two separate windows each time (the skin, and the video screen). I only really only use PowerDVD for unlocking DVDs for rips, testing my DVD authoring or for screenshots - I only watch DVDs properly on my standalone.
If there is a way to change this it would be so much more convenient for me.
Problem with mpeg2 decoder.
By tehuser in forum Software PlayingReplies: 5Last Post: 24th Mar 2009, 18:59 -
Selecting the preferred DVD decoder/codec for WMP under Vista x64
By Dark Alpha in forum Software PlayingReplies: 10Last Post: 17th Jan 2009, 21:05 -
Change the video codec or decoder WMP uses ?
By WBFAir in forum Software PlayingReplies: 2Last Post: 19th Jul 2008, 08:02 -
How to kniow which A&V decoder(s) wmp is using for my DVD?
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 19th Jun 2008, 01:15 -
Mpeg2 decoder library for developers
By Ufit in forum ProgrammingReplies: 3Last Post: 27th Dec 2007, 02:56
