  1. hello
    all, i need help, can you tell me how to set my laptop to show my dvd rips on my tv screen instead of my moniter, ive got tv out built in but dont know how to set it up.
    Dec 2002
    Dallas, TX
    Most laptops that support tv out have either a tab in the adapter display control panel or their own control panel. Mine (Toshiba laptop) is under the advanced tab in the display properties, allowing you to select TV out. If you don't have any of this, check with the laptop maker and download the latest video driver for your machine, it should support it.
  3. :P thank you i will try that
