Hello! I burned a VCD with Nero using TAO instead of DAO. It is causing many problems on standalone player. I don't have the original MPEG files anymore. How can I use the VCD contents to make/burn a DAO copy?
Also, is there a utility to determine whether a CD is TAO or DAO?
I'd appreciate any help! Thanks.![]()
You can use Vcdgear to convert the dat file(it's in the mpegav folder) on your cd back to mpg. Re-burn that in DAO. Get Vcdgear in the tools section.
Thank you very much for your reply!
Will there be loss of quality when converting from DAT back to MPG? -
No there wont be any difference in quality, because it only rewrites the header and doesn't re-encode the file.Will there be loss of quality when converting from DAT back to MPG?
Burned in subtitles help
By aftermay in forum Newbie / General discussionsReplies: 18Last Post: 30th Mar 2013, 14:24 -
How to burn DAO data disk
By logannsan in forum ComputerReplies: 4Last Post: 22nd Jun 2009, 13:17 -
burned subtitles
By ckoshikumo in forum ffmpegX general discussionReplies: 3Last Post: 20th Jul 2008, 23:32 -
DVD multitrack / DAO
By crazymoney in forum Authoring (DVD)Replies: 7Last Post: 10th Oct 2007, 01:09 -
getting movie out of a .tao
By la7oea in forum Newbie / General discussionsReplies: 1Last Post: 31st May 2007, 04:37
