Can anyone who purchased the 4X brown box Cendyne DVD burner at Office Max for $169 this week tell me what software comes with it?. The older Blue box had an impressive list including Nero and WinDVD.
What is Cendyne shipping with this new '105 style' drive? Is the software any good? What burning S/W are they providing?
Results 1 to 12 of 12
Originally Posted by RayS
http://www.cdrlabs.com/phpBB/viewtopic.php?t=8323
It's 2x DVD-R and 1x DVD-RW based on Pioneer DVR-A04, not DVR-A05. -
I purchased the Cendyne dvd burner and it is a 4x burner, I haven't installed it yet but it comes with Nero Vision and Sonic myDVD.
4x dvd-r 2x dvd-rw
Ps Kennyshin it is the 105 not the 104(this model isn't on sale) -
Kennyshin wrote:
Isn't this what you mean by the $169 Cendyne?
No. The unit I held in my hand at office max was a Cendyne DVD-R 4X machine based on the new Pioneer 105. It came in a gold/brown & white box as opposed to the -104 modele that has a blue and white box. It was clearly marked 4X but said nothing substantial on the box about software. The price after a $50 rebate was $169. -
What software is correct.
I have this DVD burner. the software (if you want to call it by that name) crashed my computer.
When loading InCD with Mydvd (included in Cendyne package) my computer would crash with a windows protection error (WindowsME).
Once I removed InCD I was able to load the MyDVD program. This program did not have help and tutorial files.
I had to download a 42M patch from Cendyne. The patch did not fix the problem.
The Nero Express program sent with burner will not allow you to burn onto the DVDRW sent with package (unless I did something incorrect).
In order to burn the DVD-RW (file more than 700M) I downloaded RecordNow program on internet.
This is a great program, I might consider purchasing it after my 30day free trial is up.
To sum it up,
Cendyne made a great burner but packaged it with crap.
PS: Be carfull about the rebate. Cendyne is saying that they will not honer our rebate.
I hope this e-mail informs everyone on Cendyne and what kind of company they are. -
It comes with the following software:
Nero Express, Nero Vision Express, Sonic MyDVD and WinDVD.
Sonic MyDVD sucks, as it always says "the medium is not large enough" which is due to the fact it uses uncompressed audio. I use Ulead DVD Factory which came with my Hauppauge capture card and it does not have the same size limit problem. -
Great dvd burner. It comes w/ nero, remember to update it to the latest version from their website. Prassi PrimoDvd doesn't work w/ mine for some reason, even when I updated the engine. It comes w/ a 1x dvd-rw. It shows up as a Pioneer A05 on my computer.
<jumling> Purchased one of these after purchasing a Pioneer. This one is going into a new machine (not completely built yet - decided on a dual AMD setup). Curious what you mean by Cendyne not honoring rebate? The OfficeMax rebate was pretty straight forward.
what I have used as software with my 4X reBanD Pioneer 105 is just about everything what I have accually used to burn so far as test was DVDXCOPY, how did it work good, I used the nero engine to burn, not the one that came with it, the one that is compadible with DVDXcopy, did it play on my sony dav -c450 yes only dvd -R (FugI- FILm)laterz
Thanks alot,
dreadogg -
MovieFactory and Primo, didnt even bother installing sonic that came with it.
BoogieMan -
I now use dvd dycripter, ifoedit, nero engine and still fugi-film I have great sucess.
Thanks alot,
dreadogg
blue ray software compatibility with standard dvd burner
By Geules11 in forum Newbie / General discussionsReplies: 1Last Post: 11th Nov 2011, 17:27 -
Nintendo 3ds slashes price to 169.99 usd
By yoda313 in forum Off topicReplies: 0Last Post: 31st Jul 2011, 08:35 -
New DVD Burner
By pepegot1 in forum DVD & Blu-ray WritersReplies: 11Last Post: 22nd Feb 2010, 23:57 -
What DVD Burner Do You Use?
By Ray&Paula in forum DVD & Blu-ray WritersReplies: 6Last Post: 20th Mar 2008, 01:01 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 20:15
