I have a DVD that has 8 episodes of a TV series. When run, a menu comes up that lets you select which episode to view. When I run a ripper on the DVD it only rips one of the episodes.
How do I get all the episodes ripped?
Thanks.
I suggest you rip with smart ripper, just cause its really easy. When smart ripper loads the DVD, make sure the Movie button is pressed in the Rip-Method Section. Then in the Source Section make sure the Input Tab is selected. In the first box right under neath the Input Tab you will see a tree diagram, at the top should be Title 1, which is the entire DVD. Then you should see Program Chains branching off. You could see one Program Chain or you could see several. Based on what you said I think that the DVD you are ripping has several Program Chains where one episode is in each program chain (some Program Chains can contain just Extras and Crap). Moving on, under each Program Chain there is an Angle. Look at the time right next to the Angle, if its around how long each episode is then click on it select a target from the target box on the bottom and hit the rip button. Since there are 8 episodes you will have to go back and open up the next Program Chain and click on the Angel and hit rip. Do that untill you have all 8 episodes.
Ummm, sry took sooo long, not good at explaining stuff ^_^
Need to burn TV episodes to DVD
By harishkumar09 in forum Authoring (DVD)Replies: 44Last Post: 3rd Mar 2013, 05:35 -
Best way to rip and encode TV episodes to DVD?
By MackSwagga in forum DVD RippingReplies: 8Last Post: 28th Mar 2011, 20:16 -
How To Rip TV Show DVD Into Episodes
By drtalk in forum DVD RippingReplies: 6Last Post: 15th Nov 2009, 13:42 -
DVD episodes to MPTS
By waveqam in forum Video ConversionReplies: 3Last Post: 15th Apr 2009, 16:37 -
How do you author many episodes to 1 DVD-R?
By 1980sumthin in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2007, 22:49
