Hello i am new here.I was in the DVD list and seen the model Koss kd 230 was there but not mine, Does the 2 at the end really make a difference or not.I was wondering if the region free hack would work on mine??.Also i am having a problem.My Star wars Episode 2 Attack Of The Clones Disc 2 (the special features disc)DVD will not work in mine, It does work but is all choopy and picture is really messed up and says "skipping bad disc area" Tried cleaning DVD didn't work.I went to try it on our Lenoxx DVD 2003 and it worked in that but won't work in my Koss.Is there something wrong with my Koss?? Any help would be apperciative.Thanks 8)
Get Blown
I have a stand alone Koss dvp2162 and when i try to record to my hard drive using several different video editing programs I get a white bar thru the middle of the picture. I guess it's macrovision so if u have any solutions weather it's hardware or a software solution it would be greatly appreciated. I've got lazy in my old age and instead of ripping the dvd an going thru that process i'd just like to use a program like ulead dvd workshop and record an edit the dvd that way, also with movies that are over 4.7 gigs I would'nt have to go thru all the extra steps of just ripping and burning it.
Thanks Rick
Viewcast Osprey 230 PCI Captire Card - Any Good ?
By wet bimbette in forum Capturing and VCRReplies: 0Last Post: 28th Nov 2011, 07:07 -
KOSS KS4110 - Piece of junk with horrible customer service
By Intuit in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Mar 2011, 11:41 -
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 02:00 -
Gateway AR-230 flashed to LVW-5001 , DDW-451s to LDW-451s, SUCCESS!
By FiremanPete in forum DVD & Blu-ray RecordersReplies: 1Last Post: 28th Jun 2008, 22:15 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 07:05
