I have read excellent thread on converting VHS / Hi8 to DVD which seems to mainly use Vdub and TMPGENC.
My problem is that I do not have a good video capture card - I am using the pass through feature on my Sony DV cam and capturing via Firewire using Pinnacle Studio 8. This creates the raw DV files at approx 13G / hr.
I am in the process of converting some Rugby games (i.e. high motion and apprx 2hrs long) on VHS to DVD and/or VCD. So far I have used the Studo 8 to do all the work - capture, edit and then burn to DVD using the auto setting (2hrs at approx 3150 tranfer rate).
Questions...
i) Would I be better using TMPGENC to encode the DVD and then a seperate DVD author software (not interested in menus etc) ?
ii) How does the quality compare ?
iii) How does capturing via firewire compare with using a capture card / V dub set up ? Would I be better getting a new card (ATI AIW ?)
Also, I am planning to put some of the less important tapes onto VCD. How does the firewire / studio 8 setup compare with my old Snazzi MPEG1 capture card ?
Chris
You can use Studio 8 to create AVI, convert with TMPGEnc and then author back with Studio 8
http://www.vcdhelp.com/forum/viewtopic.php?t=133706&highlight= -
Thanks for the response - will try your technique.
How do you find the quality of the DVD comparing encoding with Studio and TMPGENC ?
Chris -
I have used the TMPGENC Encoder and the Studio 8 combo and it works great, but a very time consuming process. I currently use Pinnacle Edition and it's good for everything but a tad bit costly. IF you have Studio 8 you can get the Edition upgrade for like 199.00. But if you are low on funding the TMPGENC and studio work well.
eteeple3, what whould be the main reason to go for Edition product ? What are the features that are most imoprtant ???
EZCap(S-Video) vs Firewire to capture VHS
By Pepepaco in forum Capturing and VCRReplies: 9Last Post: 4th Dec 2011, 12:51 -
Audio clicks-converting VHS to DVD w/Canopus ADVC-55, firewire, iMovie
By Danae in forum Newbie / General discussionsReplies: 12Last Post: 30th Jul 2010, 15:44 -
capturing vhs for restoration in vegas movie studio platinum
By Michael Rodriguez in forum RestorationReplies: 6Last Post: 28th Mar 2010, 09:38 -
How to Capture VHS-C Tapes for Editing/Authoring with Pinnacle Studio
By saroman in forum Newbie / General discussionsReplies: 5Last Post: 20th Feb 2010, 21:48 -
Mitsubishi HD-HS2000U - vhs/svhs out of FireWire port?
By mikejaz2 in forum Capturing and VCRReplies: 29Last Post: 5th Aug 2008, 21:28
