    Dec 2002
    Canada
    I am in the process of backing up my first dvd and I am using the
    DVD Decrypter
    DVD2AVI
    TMPGEnc Plus
    ChapterXtractor
    Spruce DVDMaestro
    then burn it
    When the DVD2AVI is done the *.d2v file is really small (not sure if that is a problem). But then I go to put the *.d2v file into TMPGEnc and it says can't open or unsupported. Please help. The reason I chose this method is that I can keep the chapters when i burn it.
    Dec 2002
    The Great Northwest
    If you are using DVD2AVI new version 1.77 It has some problems I could not resolve. I don't know what version you are using I had a lot of problems with the last version (1.77). I now use 1.76 always with no problems but when I use 1.77 TMPGEnc will not work with the .d2v file so I went back to the previous version and no more problems. Hope it helps
    Just to add another wrench, I just read a post that the exact reverse of what I did to fix my problem fixed their problem. So try a different version than you are using and having the problem with.
    NOTE: The DVD2AVI *.d2v file is just the frameserver for the .vobs which need to be in the same folder and directory so they can be served to TMPGEnc!
    DVD 9 to 5 ME
    http://www2.whidbey.net/mnms/
    Link for the older DVD2AVI version 1.76
    http://www.doom9.org/index.html?/mpg/d2a-mpeg2dec.htm
    Link for the newer DVD2AVI version 1.77
    http://www.afterdawn.com/software/video_software/dvd_rippers/dvd2avi.cfm
    Quote from old guide on VCDHelp
    DVD2AVI (note: you should try this new version first, but some users have had problems with it, so if you have problems opening the .d2v project with TMPGEnc, try version 1.76 from here) SEE ABOVE FOR LINK
    (;-{> Dd
    Strength and Honor
    www.dvd9to5.com
    www.dvd9to5.com/forum/
    "For every moment of truth there's confusion in life"
    Black Sabbath/Ronnie James Dio
