I used besweet to resample an AC3 file to 320kbps.
The problem is that now, even thought the sound quality seems to be almost the same, the sound volume level is much lower.
What am i doing wrong?
What should i do or use to reduce the size of the AC3 file without dramaticaly reduce the volume?
How can i fix that?
I am trying to put 3 movies (Back to the future trilogy) on one dvdr.
After spending almost 35h encoding and compiling the project, to my horror, i discoverd that my project is about 200mb too big to fit on a dvdr (4.7gig my a$$).
Since it takes so long to reencode those movies on my crapy system, i figure i can just compress the audio files a litle bit. resampling the audio of the 3 movies at 320kbps reduced the total size by about 300mb which is a perfect fit, but the volume is much lower.
How can i fix that. i realy dont want to spent another 35 hours on reencoding the movies.
Results 1 to 1 of 1
Problems importing ac3 in Vegas Pro
By mltwitz in forum AudioReplies: 0Last Post: 12th Jun 2010, 13:55 -
dts to ac3 problems
By scarlac in forum AudioReplies: 5Last Post: 23rd Apr 2010, 03:41 -
Windows 7 AC3 Problems
By eon_designs in forum Video ConversionReplies: 3Last Post: 20th Apr 2010, 05:07 -
Ac3 Downsampling problems
By robbynaish in forum AudioReplies: 1Last Post: 27th Jan 2010, 18:33 -
Fixing bad resampled DVD audio
By silverwolf0 in forum Newbie / General discussionsReplies: 3Last Post: 6th Jun 2009, 11:59
