You can pull dvd compliant mpeg2 files into PS8 then add menus, chapters, etc. PS8 will then render the project. Earlier versions of PS8 would rerender (encode) the entire project even though it was already in dvd compliant mpeg2. Newer versions have what is called smart-rendering and only render what was added such as menus, etc.) If you pulled in an avi file, the entire file needs to be rendered and/or encoded. Then the disc is compiled and either output to a directory in a format that can be burned with another program such as Nero, or burned directly in PS8. In PS8, I think rendering is a combination of adding the new material and encoding to mpeg2.
I tried to encode to mpeg2 with TMPGenc then pull the files into PS8 to add menus, etc. I usually got "Failed to compile disc" errors. I would try the exact same file again and it would work. Once compiled and burned, the menus entries would go to the wrong place on the dvd. They always worked fine in the dvd preview mode in PS8. That is why I gave up on PS8.
Results 181 to 210 of 239
I have already added these but if I save as mpeg and then go to encode software then it won't work right?
If you save as mpeg, you have already encoded it. There is no need for further encoding. Just use PS8 to create a disc. You may be able to use another authoring program at this point to create a disc, but I am not sure. -
Originally Posted by cindy3009
1. edit, cut, add transitions, titles and save as DV AVI file
2. encode (transfert, convert) to mpeg2 file
3. import mpeg2 into DVD Authoring program (TMPGEnc or PS8)
4. add menus, chapter points
5. create DVD to hard drive
6. burn files to DVD media.Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
I have one more problem with PS8
. I made a project in DV-AVI (with menu and chapters). Than I try to burn DVD in PS8. It works fine, no problems were detected. But when I try to play on my home DVD player, first 12 minutes work fine, but then the film start stoping. First a little (for about 2 seconds) and then more and more and finally everything stops...
Thanks again, that pretty much put it in black and white for me.
If I want to save a copy for archival purposes should it be the mpeg2 before importing it and then just delete the avi? Those darn avi's sure take up alot of room. -
gumpec,
Does it play ok in the dvd preview mode in PS8? Is there some significance to the 12 minutes. Is your first clip maybe 12 minutes? Did you burn it to another disc? Could be a bad disc. What brand of disc are you using? Just some thoughts. -
Thanks. Movie is 58 minutes long and play with no problems or stops in preview in PS8. DVD disc is Verbatim's DVD+RW.
Sorry, I have one more question. Is there any loss of quality if I copy my home video on DVD to another (empty) DVD?
Originally Posted by cindy3009Pinnacle Studio 8 and DV home video editing (ver.9 already home)
Originally Posted by gumpecPinnacle Studio 8 and DV home video editing (ver.9 already home)
I have a newbie question about making a disc with Pinnacle Studio v9.0.4
I created a project consisting of both videos and still photos - length of the finish video should be about 35 minutes.
When I come to "make disc" (DVD) I am trying to "create disc content but don't burn".
I push the "create disc" button and it starts rendering - it takes about 2 hours. After rendering it says that rendering is complete and it seems to stop - the "Create disc" button turns green, and I can see that Studio.exe uses only about 2-3% of my cpu.
What is happening here ???? Is it still working or what ?
Read this guide
Pinnacle Studio - prepare DVD content for burningPinnacle Studio 8 and DV home video editing (ver.9 already home) -
I have already read the info and a lot of other stuff.
Perhaps I should make an avi-file instead and then use another tool to convert to MPEG2 - or what ? -
Are you saying that Video_TS directory is empty ? It should be done.
Defrag all drives first. Check if you utilize UDMA (use latest MB drivers). Check properties of Primary and Sec. IDE Channels (select DMA) in Device Manager. Retest your drives. You may use benchmarking software like Sandra to choose your fastest drive for capture.
I have an urgent question!!! I work with Studio 8. I already made three projects. I normaly go create image but don't burn and after that I burn my project on DVD. And here is the problem. I have Plextor PX 708A - it is compatibile with all formats - DVD+-R/RW. I have one Verbatim DVD+RW disc and normaly works fine. It burns with no problem. But I have a lot of Problems with Verbatim DVD+R (Live it). I made so far three disc O.K., but I destroyed some. My latest project, I burn yesterday on DVD+RW, check it and it was O.K. But then I put DVD+R on my recorder and it works for about 95% fine and than everything stops. Is it possible, that there is some problem with the speed (Verbatim is 2.4 comaptible but when I choose 1X, it goes automaticaly on 2X - there is no 2.4X). Help me please, I'm loosing my mind!!!!!
Is there a possibility to change in finished project the name of the captured sorce. If I create the project with video1.avi and video2.avi, can I change captured source in project in gumpec.avi (video1.avi+video2.avi). So if I captured video after a while, that I name it gumpec.avi and project will recognise this like video1+video2???
hi pal if u are using SmartsoundQuicktracks maybe u can help me im lookin for a valid serial number for the following cd sets:
Cinematic Excellence
Project Millennium
Vintage Comedy
the original cds were damaged and luckily i copied them on had drive but serial was on cd so i cant install now!! -
New "almost guide"
Pinnacle Studio - dual monitor setup (nVidia)Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Originally Posted by donpedro
For people that are interested in some test results from making DVD with Pinnacle Studio version 9.0.8.5 Beta Patch
Here is test that I made on this machine with exactly 1h long DVD AVI. Project was set to maximum bitrate 7500 and MPEG sound, no transitions, no major editing, no menus.
- Windows XP SP1
- AMD Athlon 1400 MHz 266FSB
- 512MB RAM DDR PC2100
- mobo chipset VT8366-8233
- AGP 4x (only 32-bit mobo support)
- resolution 1024x768x32bit 85Hz
3:27 - Convert video
0:16 - Create second copy of video
0:02 - Create audio
0:12 - Make DVD structure
3:57 - Total time
adding memory to 1GB or different video card with hardware DirectX9 did not improved speed.Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Or.... It is as fast as Studio 8
Here is one cool test and it's results.....
Purpose was to test "hardware acceleration" option in Pinnacle Studio version 9 ON and OFF.
This one is not mine and it is posted on Pinnacles Forum:
Originally Posted by Pinnacle Forum
Originally Posted by donpedroPinnacle Studio 8 and DV home video editing (ver.9 already home) -
Another post....
Pinnacle Studio 9 - Video/Audio PluginsPinnacle Studio 8 and DV home video editing (ver.9 already home) -
In Capture mode you can see by the preview window the frame drop window. But is it this frames, which was droped during the whole captured movie or just frames, droped in one secunde???
pinnacle studio 14, more light in a video?
By computer4 in forum EditingReplies: 3Last Post: 16th Jan 2012, 09:02 -
How to Capture VHS-C Tapes for Editing/Authoring with Pinnacle Studio
By saroman in forum Newbie / General discussionsReplies: 5Last Post: 20th Feb 2010, 21:48 -
Pinnacle Studio is unable to connect to your video device
By Amyshubby in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th May 2009, 06:30 -
Pinnacle Studio 11 - Problem with cropping video
By mjkamish in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2008, 16:51 -
Best software for Video Editing - Nero, Roxio or Pinnacle Studio
By bpatters69 in forum Newbie / General discussionsReplies: 27Last Post: 28th Dec 2007, 22:11
