Ok, I am using TMPGenc to convert DivX avi files into svcd mpeg2 format. I currently use toolame as an external audio encoder. Right when it hits 100% while creating the temporal wave file, TMPGenc just closes itself. There is no error message, nothing after. What is happening? How can I fix it?
The movie file summary goes as follows:
-width: 700 pixels
-height: 390
Audio
-bitrate: 128 kbps
-audio format: Lame MP3 encoder (ACM)
Video
-Data Rate: 102kbps
-video sample size: 24 bit
the video was compressed in the divx 5 codec
Any help would be great, thanks.
Results 1 to 1 of 1
temporal degrain
By unclescoob in forum RestorationReplies: 10Last Post: 3rd Mar 2012, 22:53 -
What is the best way to treat Telecine before Temporal Smoothing?
By unclescoob in forum RestorationReplies: 97Last Post: 28th Feb 2012, 14:18 -
IVTC question - did they temporal smooth first?
By volswagn in forum Video ConversionReplies: 7Last Post: 3rd May 2010, 11:06 -
Temporal smoothing before/after shrinking frame?
By Gew in forum EditingReplies: 23Last Post: 28th Sep 2009, 19:26 -
temporal and spatial filtering
By snafubaby in forum Capturing and VCRReplies: 2Last Post: 6th Oct 2007, 10:23
