I want to add connecting lines between two points on a map i.e. moving dots following the route of an airplane traveling between two cities. Any suggestestions ? Thanks !
Microsoft Powerpoint maybe?
Panasonic DMR-ES45VS, keep those discs a burnin' -
Powerpoint doesnt seem to do it. Maybe someone else has any suggestions.
Meanwhile - Happy New Year ! -
this can be done pretty easy in swish or flash mx ... you could also even do it in photoshop as an animated gif as in the example i did on a web site ..
That sounds good however, I am new to all this and do need some more help. How do I get "swish" or "flash mx" and what do I do next ? Also, how can I find the example you did on a web site ?
Swish is my choice, but Flash is really good as well
Swish v2:
http://www.swishzone.com/index.php?dir=products/v2/demos/swf&file=texteffects7.swf&wid...gcolour=000000
http://www.swishzone.com/index.php?area=downloads&tab=downloads&product=v2
Flash MX:
http://www.macromedia.com/software/flash/
HTH
mm"The future is no longer what it used to be" -
Thanks for the Info. I just got some other advise I wish to share. Actually it is a quite simple solution. It is always 'you just have to know'. I tried it and it works perfect. Here it is :
From Transitions select top-down Linear Wipe between two graphics (one with and one without the track). To slow down the wipe enlarge the crossfade.
How to achieve this special effect
By AndrewVlcek in forum EditingReplies: 2Last Post: 7th May 2009, 10:55 -
special device for capturing HD
By adanchev in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 43Last Post: 7th Dec 2008, 11:47 -
special sub+idx
By akusoul in forum SubtitleReplies: 6Last Post: 6th Apr 2008, 05:00 -
Software suggestion to make special effect of voice
By bambam in forum AudioReplies: 4Last Post: 17th Mar 2008, 10:40 -
FLV editing, creating, and effect adding.
By Crazyj32 in forum EditingReplies: 4Last Post: 21st May 2007, 18:09
