My comp is 350mhz and it takes me about 3 and a half hours to encode half an hour of film. I was wondering how long it will take for different comp speeds, like 500, 700, and 800mhz, to encode?? I m looking to buy a computer so please let me know.
you have great almost unreal speed with a 350 ...
getting above 2ghz will be faster , anything in between will be somewhere in between ..
you can never get an exact answer to this question as there are to many varibles.. -
W2K, Athlon 2400+, 512 DDR. 2-pass VBR for a 2 hour DVD encode to SVCD is roughly 4 hours.
Encoding 2-pass XviD at 480x360 from Huffyuv capture is about 20 fps.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
hhmmm that doesnt help me much. I cant afford a 2ghz computer. My friend had a 1.2Ghz pc and it took half an hour to to encode 25mins of film. I dont need exact time.
It used to take me over 10 hours to encode a 40 min video on my 1GHz Celeron
512K SDRAM, using 2-pass VBR + filters + motion est. slowest. The source
are 720x480 mpag2, output format are SVCD. -
basically m8, if u cant offord a faster pc then consider the following:
buying more ram- this is v cheap, a 128 meg stick is about £15 but u will find it much cheaper in us
or you could overclock your pc- you shouldn't damage it as long as you have good cooling. if u have an AMD system then increase the FSB. i would advice getting some one who knows a lot about overclcocking though
Speed up Virtualdub
By graphics in forum Newbie / General discussionsReplies: 6Last Post: 24th Jul 2011, 19:13 -
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 13:24 -
Winavi Runs Slow On Old Computer Any Way To Speed It Up
By DJboutit in forum Video ConversionReplies: 6Last Post: 3rd Jan 2010, 17:36 -
converting flv to avi, speed messed up, whats wrong?
By lurky in forum Video ConversionReplies: 2Last Post: 13th Aug 2008, 00:16 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 02:41
