I just wanted to know what are you guys settings when enconding a DVD,
I always do 2 passes and Precission 9 for any DVD.
If I use only 1 pass will the movie end up that ugly??
[-Neoh*-]|[-Cheers-]
I normally use 2 pass VBR but if the movie is very dark with a lot of action then i use 3 pass to avoid blockiness.
In CCE 2.50 i set DCT Precision to Auto and it sorts it out itself but i don't think the later versions have the auto setting, if you use bitrate viewer on one of your original vobs it tells you what the precision setting is so just choose the same.
I don't use 1 pass because after going to all the hassle of ripping the DVD and re-encoding i want good results so don't mind the extra time, 1 pass comes out ok on some films but not recommended for dark or action films as they tend to come out poor quality in places
More than 2 passes
By marioval in forum Authoring (DVD)Replies: 6Last Post: 15th Mar 2010, 05:59 -
AviDemux 2.5 beta motion precision settings change?
By MilesAhead in forum Video ConversionReplies: 0Last Post: 14th Jun 2009, 15:30 -
CCE SP2 number of VBR passes
By DRP in forum Video ConversionReplies: 1Last Post: 25th Oct 2008, 02:53 -
CCE SP 2.67 Advanced Settings (VBR Bias, Quality Precision)
By seven_deuce offsuit in forum DVD RippingReplies: 3Last Post: 11th Mar 2008, 17:30 -
vbr passes in cce 2.70 sp
By DSLGuy in forum Video ConversionReplies: 1Last Post: 19th Feb 2008, 23:33
