Is there a way to re-encode an m2v file to get the bit rate down....
I am ripping with smart ripper....to a m2v file and an ac3 file....
I then Reauthor with spruce....but sometimes the m2v file is too big... is there a quick/easy way to re-encode the m2v file....
Thanks in advance.....
That would be very handy, wouldn't it?
I don't have a clue if it's possible though. -
You had my hopes up then...... when I saw the 1 reply....
Arrrrrrrrrrhhhhhhhhhhhhhh -
you havnt maybe looked at any one of the many guides here on how to do this ?
see here http://www.vcdhelp.com/forum/viewtopic.php?t=109346
Help with m2v files
By Mikhel in forum Video ConversionReplies: 0Last Post: 19th Feb 2012, 06:22 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 13:09 -
m2ts to m2v
By pcb in forum Video ConversionReplies: 6Last Post: 20th May 2010, 21:22 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
muxing m2v with m2v?
By just in forum Newbie / General discussionsReplies: 4Last Post: 30th Dec 2008, 00:05
