Both drives look nearly the same, and have had good reviews. Aopen is $30 cheaper. Not looking at the Sony anymore because I think the -R/W format is going to fail, and I don't want to spend the extra for support of a dead format. Plus it has slow read speeds.
So which of these 2 would you choose? Thanks!
Decided to go with the AOpen. You guys have been invaluable. No really.
I'll let you know how it turns out.
I have an Aopen Dvd Burner, how can I set booktype in imgburn?
By frieday in forum Authoring (DVD)Replies: 13Last Post: 3rd Nov 2009, 06:30 -
AOpen Xrecorder
By brayn in forum Capturing and VCRReplies: 2Last Post: 18th Sep 2009, 16:18 -
AOpen DUW1616/ARR Won't Burn DVD-9
By Crimson42 in forum DVD & Blu-ray WritersReplies: 4Last Post: 9th Sep 2008, 17:40 -
AOpen motherboard AX6BC
By CSULB71 in forum ComputerReplies: 10Last Post: 29th Mar 2008, 14:28 -
Aopen VX2000S Problems
By 1776AIRCOOLED in forum Capturing and VCRReplies: 0Last Post: 20th May 2007, 16:01
