The file I'm trying to author onto a disk is 3.85 GB or (4,136,302,697 bytes) mpg. The program (MYDVD autho tool) tells me the 4.7 disk is over filled to 5.47 GB. Hardly any menu at all. Background picture with one button. Why is it filling up all that space.
Results 1 to 9 of 9
MyDVD converts your MPEG audio into LPCM which takes the audio bitrate up to about 1.4Mb/s. That is what makes your files larger.
yeah, also I just read through their web site that you can only import files at the best rate wich is 60 min per disk. Truck me. Any autho tools that are very basic that will make this work?
Originally Posted by Marco33
I have a problem with ulead workshop. Just at the writing process (to DVD+R disk) it stop, because of unknown error. I think it's cause +R and not -R.
Try Spruceup for authoring,it supports ac3 and mpeg audio. I find it very easy to use and it works very well.
Isn't Spruce dead. I mean you can download it but after x time It's not usable.
Roxio MyDVD menu display
By moviegeek71 in forum Authoring (DVD)Replies: 1Last Post: 15th Oct 2008, 21:03 -
newbie question: need freeware DVD authoring tool
By kbflower in forum Authoring (DVD)Replies: 7Last Post: 20th Jul 2008, 20:45 -
Hauppage Tweek Tool question
By AlecWest in forum Capturing and VCRReplies: 2Last Post: 6th Jul 2007, 18:25 -
Limited background Audio in MyDVD 9
By cmblocker95 in forum Authoring (DVD)Replies: 0Last Post: 6th Jun 2007, 15:21 -
burning tool question.
By cowboysroy31 in forum Newbie / General discussionsReplies: 1Last Post: 4th Jun 2007, 23:08
