background info:
A link to Google
(edited: I edited that link because it was stuffing up the forum display) -- vitualis
After posting that at the beginning of the year, I m once again confused.
This is
the only thing I m sure of
1. VCD disks come in NTSC & PAL
Are these following assumptions correct
1. Any DVD/VCD player can play both these disks *irrespective* of whether it is being played to an NTSC or PAL TV
2. If a DVD/VCD player is playing a PAL disk to an NTSC TV, it will do some PAL-NTSC conversion and the resulting image will be inferior compared to an NTSC disk played on teh same player.
3. If I m creating VCDs from my NTSC VHS cassettes, its best to create the VCD in NTSC mode, inorder to avoid any record-time conversion.
Thanks a lot.
FALSE. Generally, most DVD players can play back both PAL and NTSC discs. However, many can only output a PAL signal for a PAL disc and an NTSC signal for an NTSC disc.Originally Posted by francise
If you (for example) are using NTSC only equipment (that is, you have an NTSC TV that is not multisystems compatible) then the PAL disc will not play properly on your TV.
If you, however, have a DVD player can can convert between PAL and NTSC (some do), then you can playback BOTH formats even if you don't have a multisystems TV.
Basically, to be able to playback both PAL and NTSC material you need either:
(1) a DVD player that can convert between PAL and NTSC
and/or
(2) a multisystems TV.
This is often not the case in US.
As per above. Firstly, it may not do a conversion at all so you have an unwatchable picture. Assuming that a conversion does take place, then your assumption is probably correct.2. If a DVD/VCD player is playing a PAL disk to an NTSC TV, it will do some PAL-NTSC conversion and the resulting image will be inferior compared to an NTSC disk played on teh same player.
Yes. You should avoid framerate conversions if possible.3. If I m creating VCDs from my NTSC VHS cassettes, its best to create the VCD in NTSC mode, inorder to avoid any record-time conversion.
Most newer PAL equipment is multisystems capable so they can play NTSC material just fine.
Regards.Michael Tam
w: Morsels of Evidence
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL VCD -> Proper NTSC DVD w/o Re-Encoding?
By SanctimoniousApe in forum Video ConversionReplies: 8Last Post: 4th Apr 2009, 17:59 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 02:22 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
