Hi
I've just changed motherboards and memory.
Everything is sweet but now POWERVCR2 won't run !!!!
I get this error on start-up
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:\Program Files\cyberlink\PowerVCR II\PVCR.exe
Abnormal Program Termination
Any ideas folks???
Cheers
Fozzee
http://www.david-taylor.pwp.blueyonder.co.uk/software/msvcrt-v5.zip
http://www.david-taylor.pwp.blueyonder.co.uk/software/msvcrt-v6.zip
http://www.david-taylor.pwp.blueyonder.co.uk/software/msvcrt-v6sp3.zip
http://www.david-taylor.pwp.blueyonder.co.uk/software/runtimes-setup-100.zip
install one or all of the runtimes library above untill the problem goes away ...
just a thought -- but did you try reinstalling the program first ? -
Hi
How do I install these?
The first 3 contain dll files and the fourth a setup.exe.
Yes I have tried re-installing the program. It's strange I have never had this issue before when re-installing XP.
Cheers
Fozzee -
Hi
Just installed DirectX 9 and re-installed PowerVCR2 problem still there.
Fozzee -
the 3 ones with only .dll files: You put the .dll files in c:\winnt\system32\Originally Posted by Fozzee
The setup one: Run setup and klick to install i think its the left icon at the top. -
Your first post did NOT mention re-installing XP, your second post implies that you did.
If you did in fact re-install XP, you probably need to uninstall the program, reboot, then re-install again.
To simplify, the installation program may not perform all required tasks if it detects pre-existing program files.
