i used sub station alpha and created a *.ssa file
ok, this is suposssed to be a script file and not an actual subtitle file
my question is:
how do i CONVERT IT TO SUBTITLE FILE so i can load it with my video files such as avi or mpeg2 using software like radlight or others... ???
i dont want to mix the ssa file with the avi because it lowers the quality of the vidz
also i have tried this maestroSBT and generated a so called *.son file with a couple of bmp files i dont undestand,
whats next????
im i close for reaching what i want (to have a sub file like the ones i downloaded for movies =) )?????
thans n happy new year all
Install yhis software,there is a program there called Subresync and with Subresync you can easy save it to other formats like ".srt" so you can watch it with your movie without losing quality.
http://www.divx-digest.com/software/vobsub.html
SUB STATION ALPHA 4.08 - For 64 Bits Systems
By devilcoelhodog in forum SubtitleReplies: 6Last Post: 23rd Oct 2021, 12:51 -
Hardcoding Styled (Sub Station Alpha) Subtitles to Videos
By Eudorcas in forum Newbie / General discussionsReplies: 15Last Post: 11th May 2012, 04:57 -
alpha layer trigger
By Scott Hooson in forum EditingReplies: 1Last Post: 1st Dec 2011, 07:36 -
Problems with Alpha Channel
By CKyle in forum Newbie / General discussionsReplies: 3Last Post: 9th Mar 2011, 16:02 -
Sub Station Alpha will not install
By slobjones in forum SubtitleReplies: 2Last Post: 14th Apr 2009, 15:55
