I'm trying to burn a DIVX 5 .AVI to vcd, but Nero (5.5.10) keeps telling me it's an unsupported fileformat.
Does anyone have an idea how to do this, or another program that DOES support DIVX 5 .AVI's ?
Have you installed the codecs needed?
try install Nimo Pack if you havenīt. -
DivX isn't a valid VCD format, you need to encode your AVI to Mpeg 1 to burn as VCD. Use TMPGEnc (see Tools section on your left) to encode to Mpeg 1 and then burn with Nero as VCD.I'm trying to burn a DIVX 5 .AVI to vcd, but Nero (5.5.10) keeps telling me it's an unsupported fileformat.
Regards. -
I put this in another thread yesterday but that's at the bottom of the list right now.
I would recommend AGAINST using Nero to encode your files to MPEG. Just use it to burn the disc or the BIN/CUE file. Nero is VERY slow and poor in quality for converting to mpeg. You'll be there all damn night waiting for it to get done.
I have installed the codecs, that's not the problem. I can view the files with for example WMP. Guess I have to wait for a NERO update that DOES support DIVX 5.
Take other peoples advise and use TMPGEnc to encode. It is free for mpeg1, and creates vety good quality mpegs. The same cannot be said for nero's encoder.Originally Posted by gippie99
Use nero for burning and TMPGEnc for encoding.
DivX3 to DivX5 or XviD?
By Ogilvy in forum Video ConversionReplies: 5Last Post: 13th Dec 2013, 19:24 -
Which video players can handle DivX5 files the best?
By True Colors in forum Newbie / General discussionsReplies: 1Last Post: 29th Aug 2011, 11:06 -
DIVX 3 to DIVX5
By munozsblazer in forum Newbie / General discussionsReplies: 13Last Post: 9th Mar 2008, 12:05 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
