Is there a way to just capture audio from VHS instead of capturing video and audio then I have to extract the audio ?? I don't want to capture the video. I just want to cap. the audio. Or maybe use sound recorder to record the sound ?? maybe ??
Connect the audio line-out plug of your VCR to your line-in plug on the soundcard of the computer. Tell windows to record from 'line-in'. Break open your copy of Musicmatch, tell it to record from 'line-in', press the record button on Musicmatch, press play on the vcr, and only press stop when you are finished.
Use another mp3 editor to edit the mp3 (I like mp3splitter) into tracks. -
I don't know why you would record to mp3 format. But he's right about using the soundcard. You Audigy will record fairly well. You just need an adapter to go from the 2 RCA jacks of the VCR to 1 stereo mini jack on the Audigy. Plug it into the line-in. Use a decent sound recording program like CoolEditPro, I think they have a free version. Save it as a .wav file. Then you should be able to use that for whatever you want.
Capturing a video with ffmpeg does not output audio when played
By oban in forum Capturing and VCRReplies: 0Last Post: 3rd Jun 2011, 11:11 -
Capturing game console video/audio?
By GunSlingerAUS in forum Capturing and VCRReplies: 19Last Post: 12th Dec 2009, 17:22 -
need help: topic - video/audio capturing editing software
By Uebermensch1984 in forum EditingReplies: 2Last Post: 30th Dec 2008, 00:49 -
Strange issue with audio capturing. Video is fine.
By m33ts4k0z in forum Capturing and VCRReplies: 0Last Post: 6th Nov 2008, 18:18 -
Choppy video and audio when capturing from Samsung SC-D372
By Sovideo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 14th Oct 2007, 17:08
