I am a beginner for Video Editing/Converting fields. However, I am feel very interesting in doing video. I have meet a problem as following, and hope someone can guide me.
I took the Video (using Sony - Digital Video Cam), and then using Ulead Video Studio capture the video (Pal DV Format) into the PC. After that I do the editing under Ulead Video Studio, convert it into the PAL VCD format. (.mpg), and burn it into the CD (make a VCD). However, when I play that VCD on TV. It's not clear.
Do anyone please help me on this ? Could anyone please give some suggestion and recommendation for me? Do any software or tools can make video clear ?
Thanks !
ver
You don't mention which version of VideoStudio you are using. If it is not version 6, then upgrade because the encoders keep getting better.
If you are using version 6, then if your DVD player supports it, you could try encoding to SVCD instead of VCD which should be "clearer".
Or, you could export your finished video as DV and use TMPGEnc to encode the file. This can be authored (formatted and burned) using Nero or ULEAD DVD MovieFactory.
Finally, if you stick with VCD, try increasing the bitrate to 1500 - 1700 (depending on what your player supports). The xVCD should be much clearer with the higher bitrate.
Ulead video studio 8 help
By the big man in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jun 2009, 17:02 -
Ulead Video Studio 11 (to dvd)
By Firesign in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 13:23 -
Ulead Video Studio 10 avi help
By theguy1991 in forum Newbie / General discussionsReplies: 15Last Post: 25th Oct 2007, 16:57 -
Does anyone use ULEAD Video Studio 10?? or any suggestions?
By cmlmich in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2007, 23:12 -
Ulead Video Studio 7 SE
By uricktam in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 12:14
