I have a tape that has been converted from PAL to NTSC. When watching it on the VCR, there is no problem with playpack. However, when watching through my ATI AIW, the picture flickers to black screens about once per second. The flickers are very quick. My card does not support PAL, but the tape is NTSC. Could there be a problem with the framerate of the tape?
What can I do to properly capture this on my PC (without buying a new vid card)? Any ideas?
Thanks!
when watching on the PC , the PC is non interlaced (progressive) and as such will show added fields from the conversion .
on a interlaced TV you wouldnt see this as the fields are interlaced to make a frame ..... -
so would it be possible to have some sort of progressive emulation to make the pc capture it properly?
well i suspect it is capturing it correct -- just that it looks rather bad on a pc ...
this is fairly normal ...
if you played it right back from the pc to your tv it would look ok again .. -
it is being captured with the flickers encoded into the video. i burned it to vcd and played back through the standalone dvd player. flickers are still present. can i mess with the p and b frames? will that fix anything?
PAL converted from NTSC source - Ghosting and interlacing
By OngekibouRekka in forum Video ConversionReplies: 7Last Post: 3rd Dec 2011, 13:20 -
Capturing NTSC tapes on PAL VHS and DVR
By ramrod1234 in forum Capturing and VCRReplies: 0Last Post: 23rd Oct 2009, 22:08 -
random subtitles missing after remuxing converted PAL-to-Ntsc
By spiritgumm in forum SubtitleReplies: 5Last Post: 19th Jan 2009, 12:56 -
Capturing NTSC VHS tapes to PAL Final Cut...
By willed in forum Capturing and VCRReplies: 2Last Post: 22nd Jan 2008, 17:48 -
Capturing PAL VHS and DVDs to NTSC DVD
By joelkranz in forum Capturing and VCRReplies: 1Last Post: 30th May 2007, 17:11
