Hi All,
After hitting the wall several times and after reading all excellent DVD ripping guides I came with one of my own.
This is the process I am following to rip my movies:
1. Rip using DVDDecryptor (Stream Processing Audio and Video) Watch out for the 1GB filedize in options!
2. Rename the files so they start as VTS_01_1.VOB
3. Run IFOEDIT , select Create IFO, load VTS_01_1.VOB as the first one and save. Close IfoEdit.
4. OPen IFOEdit. Load VTS_01_0.IFO in IFOEDIT and press GET VTS Sectors. Go to VOB Extras and select Corect Vob-Unit, Correct Original IFO and Create new IFO files. (Don't select Re-Mux, Strip Stream or Strip VobId)
5. Overwrite the files created in step 3 with the ones created in step 4.
5. BURN THE DVD!!!!!
Regards,
Jose
Good Job.. let me give it a whirl and I'll report with (hopefully) a good prognosis. Can you do a dummies guide for this for us newbies..
Thanks..NeoGeoSnk -
What is the purpose of going into "VOB Extras" and re-creating the IFO files?
Thanks,
Clipper453 -
HI Clipper453,
In my case if I skip step 4, my movie will play only the first second of each chapter, jumping like crazy. Maybe your Tabletop player is not as "tricky" as mine, I have a Panasonic 32K.
Regards,
Jose
DVD to MKV! I finally get it! But now...
By Hopworks in forum Newbie / General discussionsReplies: 4Last Post: 24th Apr 2011, 20:23 -
NOT finish DVD
By black lion in forum Newbie / General discussionsReplies: 3Last Post: 18th Feb 2009, 18:40 -
Error I get after I finish copying a dvd with copytodvd
By litzg5 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2008, 14:17 -
DVD burner won't finish burn
By JDShaffer in forum DVD & Blu-ray WritersReplies: 6Last Post: 15th Jul 2007, 20:41 -
Help to finish a basic DVD project with menu, chapters and videos?
By mikeli in forum Authoring (DVD)Replies: 4Last Post: 29th May 2007, 11:11
