Hello
Im about to buy a DVDburner and started to read some info on this and some other sites. But i didnt find the "Ultimate DVD Guide". And by "Ultimate" i mean that it tells you everything that you should know. For exempel:
* How to copy a DVD to one DVDr (did find it on this site)
* How to create your own menus
* How to copy the chapter part
* How to keep 1 or more subtitles (selectabel)
* How to go from NTSC to PAL
Were can i find this kind of guide anyone got any?
Its oki if the guide isnt all-in-one. If the guides are in part i can fix it so i understand what is what.
Please help me before i make a mistake and buy a DVD burner that i can backup my DVD's with.
USiT
This is only for DVD 9's that can not be reduced to a workable 4.5 GB by ripping just the main movie, if so It is just a straight rip and burn with (DVDDecrypter) another good freeware program, or whatever program you prefer,
I have had great success with this method on DVD 9 to 5. It is not all freeware but I have spent many nights and countless time on a lot of software and found this method flawless, if followed precisely, on each attempt. You have to decide for your self what works for you time, cost ect. I have made many many copy's of my DVD's and no costers since I started using this process. None of this is my software nor do I have any affiliation with the software providers I just know it makes great DVD's and it is all still available unlike most of the guides I tried that get you half way through the process and then you find out some of the software or other necessary component does not exist any more or costs an arm and a leg.
Not free but cheap
SmartRipper
DVD2AVI
TMPGEnc
Dazzle DVD Complete
Strength and Honor
Good Luck
DVD 9 to 5
http://www2.whidbey.net/mnms/ -
I don't know if you tried www.doom9.net i think it tells you how to do all of them except for the last one.
Blah, blah, blah
Ultimate Format Guide...
By DozerMayne in forum Newbie / General discussionsReplies: 5Last Post: 18th Jan 2011, 16:30 -
Windows 7 Ultimate DVD Maker Issue
By jonghyunchung in forum Authoring (DVD)Replies: 3Last Post: 1st May 2010, 11:49 -
Pinnacle Studio MovieBox Ultimate vs. DVD-recorder
By fabitos in forum Newbie / General discussionsReplies: 6Last Post: 24th Nov 2009, 07:04 -
Can I capture DVD to edit? Pinnacle studio 12 ultimate
By photonianpa in forum EditingReplies: 1Last Post: 5th Mar 2009, 05:29
