I've used VGA 1:1 ratio,
4:3 525 line (NTSC 704x480)
And when I finished the conversion, and burned onto a CD to play on my VCD player.
The subtitles shown on the TV screen are cut off, almost seems like the TV screen length is too short and the displayed show with the subtitle in the length is too long.
So, summing it all up, I can barely read the subtitles that are on the TV screen since it gets cut off.
Could anyone tell me what size or aspect ratio should I use on the TMPGEnc in order to fix this problem?
Thanks.
It is called "overscan". TV doesn't display whole picture. I believe that on of the examples from here (SVCD or VCD) comes with test pictures so you can see it on you own eyes.
Thanks for all the prompt replies.
I just did a forum search for every possible word I could think that's related to this topic.
And the best answer I've found is right here:
http://www.vcdhelp.com/forum/viewtopic.php?p=386367&highlight=overscan#386367
And everything worked out for me perfectly!
Thanks once again.[/url]
Change on-screen position of PGS (SUP) subtitles
By YankeeFan in forum SubtitleReplies: 6Last Post: 21st Mar 2022, 11:43 -
How to move subtitles on the screen with Subtitle Workshop
By Lun in forum Newbie / General discussionsReplies: 1Last Post: 7th Oct 2010, 19:31 -
Subtitles appear in the menu but no on the screen
By dexter30 in forum SubtitleReplies: 4Last Post: 25th Feb 2010, 22:35 -
2 identical wording subtitles on the screen
By workman in forum SubtitleReplies: 4Last Post: 19th Jan 2008, 18:49 -
Problems with Subtitles Position on screen
By impulse_16 in forum SubtitleReplies: 11Last Post: 27th Oct 2007, 11:06
