I have used BeSweet to create AC3 files and now I would like to put them to make an Audio-DVD. How can I do this. I have the lastest Nero and Easy CD Creator 5.0 Platinum. Any help would be great!
The best way is to use an authoring program such as Ulead VideoStudio 6
and choose the lowest bitrate,that way it will be properly encoded and burned.
Here's a DVD-AUDIO link:http://www.digitalaudioguide.com/faq/dvd-audio/faq_intro.htm -
animefan72001, can you tell me how to use Besweet to change my mpeg1 layer 2 audio from 44.1hz sampling rate to 48hz sampling rate, if not could you just tell how to use the basic features of this program.
Okay, once you have selected your Input and Output files, you need to do a couple of things. To get from 44.1 to 48...
1) Under BeSweet, click "Downconvert Sample Rate"
2) Click SSRC to the right.
3) Check the box called "Set Sampling Rate of Output File"
4) At the end of that line, it should say 44.1, change it to 48000
5) And lastly, I don't get the clearest files unless I "Attenuate Volume of Output Level" by 1
Hopefully that helps. And thanks for the link to the Audio DVD thing.
How to create an Audio-Only DVD in DVDLab Pro (IMPROVED)
By GordRocks in forum User guidesReplies: 26Last Post: 15th Jun 2023, 06:55 -
Create DVD Audio Patch?
By Spawn1985 in forum Authoring (DVD)Replies: 23Last Post: 3rd May 2010, 23:25 -
How do I create a Digital Audio DVD?
By chrisf71 in forum AudioReplies: 10Last Post: 25th Jul 2009, 22:00 -
create dual audio dvd
By jin007 in forum Newbie / General discussionsReplies: 4Last Post: 9th Aug 2008, 17:38 -
How would I create an Audio DVD from my audio files from scratch???
By Hittz in forum AudioReplies: 6Last Post: 10th Jun 2007, 03:15
