I'm just wondering, the program won't work for me no matter what I try....
I went to the cinema craft site and I'm not gonig to pay 2000 dollars for it...WAY too expensive.
So i come to my last question - Is there another free alternative?
Closed Thread
Results 1 to 30 of 39
bbMPEG is probably the only reasonably good and completely free MPEG-2 encoder...
The results aren't as good as TMPGEnc or CCE and it is slower, but it is completely free.
It's also great as a muxer so it's worthwhile getting a copy.
Regards.Michael Tam
w: Morsels of Evidence
Before using Tmpgenc, make sure you do a reboot of your system to maximize resources. After return to the desktop, shut down all background processes (Antivirus, etc). You didn't specify OS, but Win98 or Win ME press ctrl+alt+del to bring up menu of background processes. Choose 'end task' for each background program EXCEPT Explorer and Systray. I've also found it useful to disable screensavers and power schemes (set Power Management in Control Panel to 'Always On.'
Hope this is useful.
Your computer details will not help ..This is software, not hardware.
First , what version of TMPG
2nd Did you get the VFAPI plugin
If yes
Did you run the VFAPI plugin after install
If no
Run VFAPI plugin
Next , environment is very important
Under OPTION , ENVIRONMENT SETTINGS
CPU tab - I have
ENABLE MMX
" MMX-2
ENABLE SSE
ENABLE SSE-2
Not sure if that is valid for your AMD, you tell me the processor capability
Next click the VFAPI plug-in tab
Mine will have more possibly but for the key ones I will highlight.
AVI2 - 0 priority
BMP/BPM/JPG/etc Reader - 0 priority
CYBERLINK MPEG 2 - 0 priority
Ligos MPEG2 - 0 priority
Microsoft MPEG1 - 0 priority
Wave file reader - 0 priority
AVISYNTH Virtualdub - 0 priority
DVD2AVI project filel reader - 0 priority IMPORTANT
MPEG2 Video Plug in - 0 priority (important if you have Mpeg 2 plugin)
Quicktime movie reader - 0 priority (only for quicktime)
TMPG project file reader - 0 priority IMPORTANT
Direct show multimedia - -1 priority Important
AVI VFW compatibility reader - -2 priority
I would start in these places ...also give a description of what you do and how it fails...Hope this helps
If yes
If no
Run VFAPI plugin
The Athlon should work with that...except I beleive sse-2 ia p4 only process...I'll check that out. but now that i think of it i think no, b/c the p4's FPU uses SIMD to make up for shortfalls (and it still doesn't do the job to perfection...) while the AthlonXP has a REALLY strong FPU (unlike the k6-2....) so it can do that number crunching...
I know how to work with that...
but VFAPI plugin?
Please define "won't work".
Lock-up? Reboot? No Response?
I have run 4 or 5 versions of TMPGenc on 3 or 4 different PC, All AMD, never had any significant problem.
What codecs are installed?
Previous suggestion is correct, this is software problem not hardware.
What EXACTLY have you tried?
I have never seen anyone post that they could not run TMPGENC in almost 2 years.
Originally Posted by Nelson37
I've also started noticing that on some of them, when you go through the encoding setup, unless you manually set the beginning and ending points (these are 45 minute shows), TMBGEnc thinks they are 110 minutes long.
Most new Divx's have AC3 audio and will encode no audio unless you follow the guide http://www.vcdhelp.com/forum/userguides/91588.php
Panasonic DMR-ES45VS, keep those discs a burnin'
Here are the codecs I have installed
Cinepak Codec by Radius Inc.
DivxMPEG-4 Video Codec (fast-motion)
DivxMPEG-4 Video Codes (low-motion)
Divx 5.0 Codec
Huffyuv lossless codec [HFYU]
Indeo Codec by Intel
Indeo video 5.10
Microsoft mpeg-4 Video Codec v1
" RLE Codec
" Video 1
msh261.drc
msh263.drv
msyuv.dll
VFAPI Reader Codec v1.05
TMPENC Error
Read Error ocurred at address 0049EECD of Module 'TMPGEnc.exe' with 00D4AFF4
CCE Error
cce encodinh failed: Error: Video check-sum is different from that of previous pass. source video data or time code may be different
Please check videotape or the information file
please check videotape or the information file
---information---
current: checksum= 01bdeaee
previous: check rum = 01bde9f8
Originally Posted by kitty
Without HeadAC3he, the whole process is pretty pointless, isn't it?
MAGOMAGO - you appear to have some sort of Hard DRive read error, or possibly a corrupt video file. Try some different files from different sources, re-download and re-install software.
Do a complete scandisk and defrag, Norton Disk Doctor if you have it.
The "READ ERROR" indicates a corrupt file, either program or input, CCE giving same error points to either source file corruption or HD read\write problem.
I've tried it on 4 different files....
Hrm...I don't have any Norton stuff....
But if the HDD died i'm going to go beserk...
Though I split my hhd is a 50 and a 20 (leaving 10 for linux when the new distros come out that support all the features my new mobo has) with the 20 as storage.
Damn....
Are there any programs that burn test the ram/hdd?
BDFree freeware released, decrypt Blu-ray/DVD - free alternative to anydvd
By bdfree in forum Newbie / General discussionsReplies: 23Last Post: 28th Sep 2012, 10:25 -
Free & simple alternative to DVD Maker for my father
By heyjjjaded in forum Authoring (DVD)Replies: 5Last Post: 19th Jan 2010, 17:58 -
AVG free antivirus alternative
By samijubal in forum ComputerReplies: 37Last Post: 5th Jan 2010, 18:42 -
Free alternative to Nero
By ddongle in forum Newbie / General discussionsReplies: 4Last Post: 23rd Dec 2009, 13:19 -
Any Free Alternative To DVD Decrypter For Ripping To Single VOB?
By DarrellS in forum DVD RippingReplies: 9Last Post: 11th Feb 2009, 00:41
