I am trying to capture from VHS tapes using an ATI AIW 8500DV card and Adobe Premier 6. I then want to edit various clips (trimming and joining, etc.) to make one file, and then export back to VHS.
What Codec, Frame Size, etc. should I be using to get it to work? I was able to capture using Divx Low-Motion Codec, but I get some dropped frames. More significantly, however, I cannot get Premoer to export back to vhs. Sound will work, but not video. I assume this problem has something to do with the Code, frame size, or even whether I select upper or lower filed.
Can anyone help? Are there any guides for this process?
The problem with not being able to output video probably lies with the overlay; I beleive, with the AIW you need to ahve overlay selected in the video output. I haven't used premiere for a while and don't have it installed but if you see something like that in any of the menus try changing it. That or use your ATI app to output to the composite out.
uploading youtube videos - appropriate export format...?
By Bansaw in forum Newbie / General discussionsReplies: 2Last Post: 30th Dec 2011, 13:30 -
which format should i export my imovie projects to
By Lu-min Chew in forum Video ConversionReplies: 1Last Post: 6th May 2009, 03:18 -
Can't export in flash format
By jweb in forum ffmpegX general discussionReplies: 18Last Post: 4th May 2009, 23:13 -
What is the best export format from Vegas for later FLV conversion?
By Gargalash in forum Video ConversionReplies: 1Last Post: 15th Apr 2008, 01:20 -
Using Canopus ADVC110 to Export to VHS from Final Cut Pro
By richisgame in forum MacReplies: 4Last Post: 14th Sep 2007, 20:18
