I have a DivX file that I want to convert to DVD. I want the DVD to be standard NTSC with 16:9 aspect ratio. Right now the DivX file has a 2.35:1 aspect ratio. So what I need to know is what are the dimensions of a widescreeen (2.35:1) NTSC DVD with a 16:9 aspect ratio NOT INCLUDING the borders at the top and bottom. I need to know this because that is what I need to resize my DivX file to before encoding it. Thanks for any info.
I believe it is 720x368 without the borders. Try using FitCD, if you load your DivX into the program it can tell you the resolution you need to resize to before you add borders and it can also write an AviSynth script for you(or at least one to start from if you feel like using more advanced features of the script).
DVD Lab Pro Menu Resolutions
By Anonymous344 in forum Authoring (DVD)Replies: 0Last Post: 6th Dec 2010, 17:11 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 05:07 -
Issues Authoring DVD with different resolutions
By Smack2k in forum Authoring (DVD)Replies: 3Last Post: 11th Nov 2009, 02:24 -
DVD screen capture resolutions???
By cabala420 in forum Newbie / General discussionsReplies: 4Last Post: 25th Apr 2008, 11:28 -
Is there a list of supported resolutions for DivX certified DVD players?
By quitearush in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Jan 2008, 05:26
