Hi,
XP Home (No SP's installed)
Hauppauge WinTV PCI-FM
VirtualDub 1.4.13 (Pentium 4 optimised version)
Previously capturing perfectly fine, but however can now only capture in mono. The sound is in stereo when using the Hauppauge Tuner software, but the minute I switch to capture mode in Virtualdub , the sound switches to mono. This is before I actually start capturing and is not related to my audio capture settings - as far as I can tell. The actual capture is in mono as well.
When using the inbuilt capture option in the Hauppauge software, the sound does remain in stereo, but I'd much rather use VirtualDub to keep a track of dropped frames, etc.
I have installed Visual Basic.NET recently, and can't honestly say if it has worked properly since then. It would appear VB has modified something, but I'm at a loss as to what.
Anyway, Any ideas?
Any and all replies greatly appreciated
Steven
I trashed that cap program and downloaded the driver at btwincap.sourceforge.net and use virtualdub and virtual vcr. Hopefully you won't have many dropped frames......Originally Posted by onedunpark
Where Can I Buy a mono-stereo 3.5 mm mono to stereo L-adapter?
By solarblast in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Nov 2009, 06:45 -
mono to stereo?
By wingfan in forum AudioReplies: 5Last Post: 22nd Nov 2008, 13:44 -
mono and stereo?
By sharmine in forum Newbie / General discussionsReplies: 9Last Post: 12th Apr 2008, 22:24 -
Two mono channels
By Digiface in forum AudioReplies: 4Last Post: 13th Jan 2008, 14:14 -
Converting a Mono Left Channel to Double Mono Left/ Right Channel on a DVD
By socool135 in forum AudioReplies: 5Last Post: 16th Sep 2007, 01:45
